Materials custom shared parameters update issue
Dear All,
My name is Bernar Morote and this is my first time posting a question, so I would like to apology in advance, in case that I can do something wrong.
I have an issue when i try to update a custom share parameters associated to my materials. I have explained what I do and what it happens to me in the attached document.
Thank you very much for your assistance in advance.
Kind regards,
Bernar.
Are you saying you added a Project Parameter to the Material Category, or are you saying the you the edited/added information to the existing Parameter fields of the Material?
If Project Parameter, that needs to be "transferred" to other Project via "Transfer Project Standards".
If you created/modified a Material, then you need to add the created/modified Material to the adsk file via "Add to".
Hello BarthBradley,
Thank you very much for answering my email.
I am afraid it does not work still :-(. See my comments in the attached document.
Thank you for your help.
Kind regards,
Bernar
Material Custom Parameters are Project Parameters. They only live inside the Project. Use Transfer Project Standards to transfer Project Materials and Project Parameters between open Projects.
Hello barthbradley,
Thank you very much for answer. It is clear now to me that the values that I introduce in the custom parameters are values stored only in the project / template.
Thank you very much also, to let me know how to transfer this values from one project into another.
Kind regards,
Bernar.
