Hello all! I am trying to figure out how to export a SketchUp model into Revit. I have looked all over YouTube and cannot seem to find out how to do so. If you have any clue on how to export a SketchUp model into Revit, you would help me out greatly. I am using SketchUp Pro 2020 and Revit 2021. Thank you in advance!
Insert - Link CAD file - change file type to SKP.
Make sure you back save your SKP file a bit.
Also, link into an In-place Generic Model so it will cut properly.
My preferred method is to import SKP into AutoCAD via the "ImportSKP" Add-In, Save as DWG, and insert DWG into Revit.
