Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Materials cannot be displayed on free-form surface models.
akira
akira
I am trying to input data such as "Material" into a free-form surface model in Revit family.
In order to input "material" into free-form surface models created by multiple software such as Inventor, I did the following.
I created a "Family Type" > "Materials and Finishes" and selected the material I wanted to display (cherry).
At result, the cherry wood grain does not show up and only a single color is displayed.
If there is a solution to this problem, please tell me how to do it?
A file of the free-surface model will be sent to you.
I'll do my best, so thank you in advance for working with me.
RDAOU
@akira
  • Normally you would set material by layers but considering the surface you have from inventor, Explode object >> Select surface >>> Associate Material Parameter
  • The cherry grain will show when you switch view to realistic mode
See GIF below
syman2000
You can also go to import>object styles and then add material.
