Good afternoon,
I have a roof and a wall having the same material. Hence, there is no fascia for the edge of the roof. The default roof settings shows a blank texture on the roof width ( in the place a fascia would have existed, but is not the case here). Please assist me with some ideas.
Thank you,
Dan
Solved by arunag. Go to Solution.
Hello, you can use the Paint tool in Modify tab ...select the roof material and click on the face.
Problem solved. I applied material to fascia and then also Join roof to wall.
But how do you do it without having to manually paint every roof edge? I'd prefer to have it built into the roof family so that I wouldn't have to do that.
