Material Takeoff counting much
ARMK
ARMK
Hello
I have a problem with the material takeoff, it is counting too much.
According to this picture below, both materials yellow and blue should be around 3 "metersquare" but as you can see the blue one is counted from "1meter length x 4meter height to 4m2" and the yellow one from "0.75meter length x 4meter hight to 3m2".
Why is revit adding the thickness of the yellow wall into the blue walls length and how can i solve this?
Thank you for now.
Avaris.
That is the way Revit works, wall layers and take-offs are always rough estimations because the wall joins are not calculated correctly. One 'solution' is to create walls with only one layer, this will result in more correct calculations.
Karol_Piroska
@ARMK you can create parts and shedule these instead. You will get a better result.
ARMK
Could you explain the section with parts please.
__
How do I have to handle large scaled projects when revit doesn't give me accurate information.
I mean do I have to take care of every Wall induvidiual to get an exact result?
Karol_Piroska
@ARMK select your walls, create parts by selecting create parts tool in create tab. Create parts schedule (select parts not walls), add required fileds. To see parts in a view, got to properties panel and select "show parts" under parts visibility.
