Material Problems Tint and Brick Pattern
Message 1 of 18
hello,
tried to change brick pattern and tint on brick common and it is not letting me. i looked into phasing as well as graphics and everything seems to be fine.  i am attaching a screencast as well as the file. pls help
Replies (17)
Message 2 of 18
I'm looking at your screencast and your rvt file...I don't see where the problem is. What am I missing?
Message 3 of 18
Sahay_R
BTW - I did change one of your walls to a violent pink with a different brick pattern
To change tint - Manage tab>> Materials
To actually change the material -
To change the appearance of the actual material -
Any further tweaking would need to be done in the image itself, using possibly Photoshop.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 4 of 18
Thanks Rina,
The problem lies in the fact that the tint does not show and when I try to change the brick pattern to herringbone or something else it does not show either. the brick pattern always shows as "brick common" and nothing else.
Message 5 of 18
There are surface pattern for hidden and shaded view and appearance pattern for rendering. You have to change both.
Message 6 of 18
 it is very important that you take a look at my screencast and you will see what i mean.   i am trying to use Paul Aubin's tutorials on how to change materials. When I use this particular file, the instructions do not seem to work but when I open up a new file everything works fine. when i check off the tint tab it does not show.
Message 7 of 18
That's what I'm talking about...I am able to change at my end just fine.
Message 8 of 18
how do i do that?
Message 9 of 18
So - from what you are saying - you cannot replicate this issue in another project? Is that correct? Only this one project - which I am having no issues with whatsoever.
@ToanDN: Help me out here please. Would you check out the rvt file and verify that I'm not crazy here.
edit...I'll say this: opening that file caused Revit roll-back my driver! Had to close-out of Revit and update my video driver through device mgr.
Message 10 of 18
Sahay_R
Are you changing the actual material, or are you making the change I had shown in my first screenshot? Once again, I was able to change materials in your model with no problem....at the bottom of my screenshots you can see my lovely bright pink wall....
If you change the material itself - did you check the Use Render Appearance box?
Rina Sahay
Message 11 of 18
Thanks for sharing that little nugget, @Sahay_R. I feel better knowing that you had no problems with the file either.
Message 12 of 18
Sahay_R
@barthbradley Always glad to entertain! I hope you didn't miss the bit about the lovely pink wall. Violently pink would be a better way to put it.....
Rina Sahay
Message 13 of 18
thanks! i don't think i am making much sense here. to change the tint please click on the tint box instead (it's on the bottom under appearance). please try to change the masonry to flemish cross. whenever i change the masonry to anything else it always reverts back to brick common.
i am not having problems with changing the colours. rather i would like to know why the tine box does not work and why my masonry always reverts back to brick common.
Message 14 of 18
i am not having problems with changing the colours. rather i would like to know why the tint box does not work and why my masonry always reverts back to brick common.
Message 15 of 18
genius!!!
Message 16 of 18
@Sahay_R thank you both for your time. i figured it out.
Message 17 of 18
well, what was the solution?
Message 18 of 18
@barthbradley  I opened the Revit file just fine.
@Anonymous  Tint color works best if the texture image is in grey scale.
