@drake_taxon @adariz76
Currently there is a 2025.4 update not sure if the templates got updated as well.
In general it depends on the template used and what materials/patterns are loaded into it and the graphic settings these material use...The pattern itself would not be saved/embeded in the Material Library but more like referenced/pathed to it. in 2025 at my end (based on the setup I have been already through)
- if I use the default Architectural US English, the same material you showed looks like the below Image.
- if I use the ResidentialGBR English one, it looks different (see GIF)
The issue which you are describing might be due to the different Schema used in 2025 and and the changes they introduced to pattern definitions. When a material from an .adsklib is imported into Revit, the software may override certain properties (like patterns) with defaults if it cannot find a direct match. Moreover, opposite to how revit does not support backward saving, when it comes to material libraries Revit's .adsklib files are backward-compatible but sometimes not fully forward-compatible.
An easy fix to your issue is to simply open your current 2025 template and the other template from 2024 which you like then do the following
- On the Manage Tab >> Sttings >> Transfer Project Standards
- Select Materials
- Hit OK
- When asked, click overwrite
- Once done save the template for future use
