material browser not popping up
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
lrnz_ellison4DAKD
842 Aufrufe, 5 Antworten
Hi there I need some assistance with this problem, I have tried everything I know possible this is the only option I have left. I installed Revit 2020 and 2021 everything works fine until I try to open up the material browser, nothing happens. the screen just flashes and then nothing. I cant add any material through the material browser can anyone help me solving this issue, please. most appreciated.
5 ANTWORTEN 5
Nachricht 2 von 6
alan_eu
als Antwort auf: lrnz_ellison4DAKD
It´s probably a graphic card problem. Try to disable it...
How? File - options - hardware. Then, restart your Revit.
Also, try these options:
1. Update your Revit using Autodesk Desktop
2. Sometimes you couldn´t successfully install the Material Library;
3. Update your graphic card driver
Please, let me know if it worked :leicht_lächelndes_Gesicht:
Alan Araújo EESignature
Bee1ColabInstagram Alan Araújo RevitBee1ColabGrupo Whatsapp
Usuários do Autodesk Community:
  • Se a resposta resolveu o seu problema, clique em Aceitar como Solução! isso ajuda os outros usuários a encontrar rapidamente uma resposta e Curta se gostou :leicht_lächelndes_Gesicht:
  • Manda um alô nas minhas redes sociais com +600 vídeos de de Revit/BIM, Templates e conteúdos semanais! Gratuitos! :leicht_lächelndes_Gesicht:
Nachricht 3 von 6
lrnz_ellison4DAKD
als Antwort auf: alan_eu
Thanks for your advice, greatly appreciate it. it was, in fact, a graphics card issue there were two graphic cards installed. the material browser pops up now.
thanks a million, you were of big help.
Nachricht 4 von 6
alan_eu
:nach_vorn_stoßende_Faust::lächelndes_Gesicht_mit_Sonnenbrille:
Nachricht 5 von 6
lrnz_ellison4DAKD
:lächelndes_Gesicht_mit_Sonnenbrille::Ruf-mich-an-Hand:
Nachricht 6 von 6
cn22mg
Hi, none of this worked for me, are there any other solutions?
