Material appearance is not matching b/w Revit and Navisworks.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Could you pl have a look at the images shown below, the tile pattern (both ceramic tile and wooden tile) location and orientation is not matching b/w Navisworks (First image) and Revit (Second image).
Difference in Ceramic tile could be seen at Column base and the wooden tile orientation is obvious.
The ceramic tiling is default Revit material ( refer bottom most image) while the wooden texture is an image loaded into the material appearance. FYI.
Pl help me to fix this issue. Your any tips would be highly appreciated.
Thanks in advance!
NavisWorks
Revit
Thank You! and please 'Accept As Solution' when you found a solution, to help others.
