Hi everyone
a couple of my classmates and I have set up a LAN at our residence and we are collaborating using file based worksharing...my question is related to materials and material assets created on local models...
I read somewhere here that when transferring the model to a different workstation using usb or external drive (sometimes) not all materials and assets are transferred with the model and one would need to copy the material library with it which got us a little bit confused. On a file based worksharing
- are materials and material assets created on local model transferred to the central when syncing? (Currently each workstation has the material and asset libraries stored locally on each machine as per default Revit installation.
- Is there a way to have a central materials and assets library on our server? If yes; How can we set up our Revit on the local workstations to point to those files and save to them?
- do we need or is it better to have Revit or any other application also installed on the local server to manage things on the central or is it sufficient to do it through one of the workstations? (Currently no Revit on the Server; only the shared folder)
anyone knows of a guide on how to properly set up a file based worksharing on a LAN and what applications are required if any to manage the central model. I found lots on Revit Server but nothing worth noting on file base...
I am open to accept any information and thanks in advance
Jason
