Material and Decals
Material and Decals
Message 1 of 8
Material and Decals
Artboard 1.pngHello,
Would anyone know how I can uniformly put a jpeg image of a pattern  that I designed on the cone of this interior. I tried my best to play with the setting but these lines show.
Please help.
Replies (7)
Message 2 of 8
Viveka_CD
Hi @Anonymous
Can you post a screenshot of the settings?
Do you want a bump in the pattern?
Message 3 of 8
Hi Viveka,
I actually modeled the interior in Revit Mass then brought it into Revit Project. I designed a pattern which I then applied to all the walls. For some reason when I apply the pattern to the Cone and the Roof it shows up weird. I dont have a bump in the pattern
Here are the settings
Message 4 of 8
Here is the revit file of the project
Message 5 of 8
i also attached the revit file of the project
Message 6 of 8
Viveka_CD
Hi @Anonymous
The settings are all ok.
A few things to check:
1. Are you sure the pattern you created does not have a black outline or border?
2. Try to make a duplicate and crop the pattern and reassign.
3. Can you select the lines and override the graphics - make them not visible?
4.See  article on Aligning the Render Appearance to the Surface Pattern
If none of the above work, can you share the pattern and part of the model so I can test further. I can share a private folder if you'd prefer.
Message 7 of 8
Viveka_CD
Hi @Anonymous
Please share the pattern as well, and let me know how you would like this to appear?
Message 8 of 8
Viveka_CD
Hi @Anonymous
I see that you have marked the solution. Just checking if the recommendations helped resolve your issue?
Let me know if you have additional questions and good luck with your project.
