Revit 2018 Visual Problem
25 ANTWORTEN 25
Nachricht 1 von 26
1295 Aufrufe, 25 Antworten
I have a problem like in the below photo. Any suggestions ?
25 ANTWORTEN 25
Nachricht 2 von 26
-FDC-
als Antwort auf: Anonymous
Graphics card driver.
What card do you have ?
Nachricht 3 von 26
Viveka_CD
Hi @Anonymous
Do you have a multiple monitor setup? If so, disable and check the primary monitor.
Please try the below for me:
  • Check for latest updates from the Desktop App.
  • Disable Hardware acceleration and see if this issue persists.
  • Update you graphic card driver form the manufacturer's website.
Nachricht 4 von 26
Viveka_CD
Hi @Anonymous
I just wanted to follow up here, any progress on this issue?
Let me know if you have additional questions.
Please mark any posts that help with "Accept as Solution" and thanks! Kudos welcome.
Nachricht 5 von 26
als Antwort auf: -FDC-
NVidia Quadro P3000
Nachricht 6 von 26
Viveka_CD
Hi @Anonymous
Please update your graphics card from this link
This may fix your graphic display issues.
Nachricht 7 von 26
als Antwort auf: Viveka_CD
Hi @Viveka_CD,
I did what you recommend. Update drivers but the same. :enttäuschtes_Gesicht: Should I try to install Revit again ?
Nachricht 8 von 26
Viveka_CD
Hi @Anonymous
Try a repair first, it if does not work please try installing Revit again!
Nachricht 9 von 26
-FDC-
Did you check if Revit is using the Quadro ?
-> File -> Options -> Hardware
Nachricht 10 von 26
Viveka_CD
Hi @Anonymous
Nachricht 11 von 26
No. Nothing changed.
Nachricht 12 von 26
-FDC-
Did you check if Revit is using the card?
Is it a laptop or a desktop?
Nachricht 13 von 26
Of course. Its a certified card.
Its laptop Dell 7720
#- Please type your reply above this line -##
Nachricht 14 von 26
Viveka_CD
Hi @Anonymous
I'm sorry to hear that!
Can you please send me the recent journal file to test further? I can share a private upload folder.
Looking forward to your reply update.
Nachricht 15 von 26
I can send tonight but i dont know what is journal file ?
Nachricht 16 von 26
Viveka_CD
Hi @Anonymous
HERE is information on the location of the journal file.
I have just sent you a link to a private folder. Let me know if you have issues accessing the folder.
Please upload your journal and Revit model and I'll be happy to test it for you.
Nachricht 17 von 26
-FDC-
That is not what I mean.
I have seen lots of people with workstations and expensive quadro's who are using the built in intel CPU graphics option.
It is perfectly possible that Revit is not using the quadro.
Check it please.
Nachricht 18 von 26
Could you tell me the way ?
Nachricht 19 von 26
-FDC-
File, options (see screenshot)
Then click hardware and look what Revit says at "video card".
Nachricht 20 von 26
-FDC-
Did it help ?
