Massing and adaptive components
Hi Everyone,
I am trying to create a roof in the project environment using mass/ adaptive components and not succeeding so far.
For some reasons the adaptive components hosted in the pattern base family (mullions) are continuing further to the actual form and showing some odd dots like if they were sectioned (please see pictures).
Any idea why this happens will be highly appreciated.
Thank you for your help
Silvia
You may be experiencing the 2 inch overlap phenom. A known issue.  Drives me fricking crazy.
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
...can you post the family to verify?
Thank you Barth, you were right, I moved one of the line slightly away from the level and it worked.
UnfortunaletyI am not able to post the family, it's a model in mass.
I followed a video on line from Chapman and Taylor yotube channel and it helped me overcoming the issue.
I have posted the link in case someone else will encounter the same same issue.
Thank you very much for your reply
Have a good day!
Silvia
