Print missing line in elevation view
10 ANTWORTEN 10
GELÖST
Nachricht 1 von 11
noconnorG728Y
1814 Aufrufe, 10 Antworten
Hello
When I created the interior elevation view and sheet. All seems fine until I want to print the sheet. I am missing lines on the printing sheet.
So I am here at the last resort. Attached is the PDF of the sheet
Any suggestion as why it is happening?
10 ANTWORTEN 10
Nachricht 2 von 11
als Antwort auf: noconnorG728Y
@noconnorG728Y
Can you please mark and show us or attached the rvt file to have a check.
As when i printed your pdf, I can see all the line printed. Can you pls show us wat lines are missing during print.
This is your printout.
Nachricht 3 von 11
noconnorG728Y
als Antwort auf: Anonymous
Ok I am attaching a screen shot of the interior view as shown. All lines are present but when  I printed, some lines goes missing
Nachricht 4 von 11
@noconnorG728Y
Is your Show Crop region Turned on??
Nachricht 5 von 11
noconnorG728Y
Yes, the crop region is turned on
Nachricht 6 von 11
@noconnorG728Y
Do you have any design option turned on in your view template?
or Have did you assign any view template.
If you have design option -> Check whether is design option is set to <Automatic>.
Nachricht 7 von 11
noconnorG728Y
No Template or design option. I only created phasing.
Nachricht 8 von 11
This is my last try give you option is "Did you use Edit Crop option or Did you try to Unhide categories"
"Did you try open an new file and model some simple element and do a quick  sheet and drag in the view try to print and see whether it is happening in the new file also,please?"
After then - Final thing is "We have to check the file and only tell you whether there are some issue in your visibility setting or export PDF option or the file itself"
Problem can be found only when we get the file , open and see it.
I know you cant send your office working file due to work ethics(can see it from you screenshot).
Nachricht 9 von 11
Uncheck Hide Crop Boundaries (in Printer Setup)
Nachricht 10 von 11
als Antwort auf: barthbradley
@barthbradley
He's got the solution... thumbs up Smiley (fröhlich)
Why didnt I think of this... Verlegener Smiley
Nachricht 11 von 11
noconnorG728Y
Yes! It is working now.
Thank You!
