Masonry wall interaction at inserts
patrickKU32M
Observer Observer
patrickKU32M
Observer
Observer
Hi All
I am trying to get Revit to represent brick walls correctly at inserts and junctures when building with brick cavity walls. The incorrect skins end up linking / wrapping.
I have attached an image showing what my model looks like and a sketch indicating what the walls should look like (in red).
Any help would be greatly appreciated.
jay_colcombe
You will need to create a couple of duplicate Wall types and change the core and numbering priorities to interact accordingly.  This link should help with the process.
Autodesk Revit Tutorial - Continuous Cavity Wall Joins | GRAITEC
Jay Colcombe
Autodesk Certified Instructor
Simon_Weel
For the Doors, you have to set a ref plane to act as a 'wall closure'. The location of that ref plane defines how far the wall will wrap. I exaggerated things a bit in this example:
... but it shows what happens when you switch on the wall closure.
