- Mute
- Permalink
- Report
Revit 2025 being used.
I have a line object that I use to show flows of movement (people, equipment, etc) around a facility. To avoid the lines crossing directly, I've included a Masking Region, so the lines will visually break at the crossing (it isn't important which one gets broken).
The result I see on the screen, is what I want, which is not what I get from vector processing, which I'd prefer to use, as it is faster and a better result.
Any solutions?
Revit screenshot, showing what I want is displayed:
The print result, using Export to PDF and Vector processing, this has the lines merging.
The Revit family I created to explain the issue, attached.
I'm using a Line based generic model, with the linework done as Cut type, as I'm controlling colours in my drawing using filters and I need that rather than Projection type.
I'm doing also as Symbolic lines, I've tried Model lines and it doesn't work with the Masking Region which unsurprisingly blanks the model lines.
