Mask or no mask, I still don't see you...
yes_and_no
Message 1 of 9
yes_and_no
Guys, for Reno proj we do plumbing ourselves. For the last two years cities in usa do plancheck online and we found multi color plumbing lines helps a lot with clarity (yes, we don't care how it look on blueprint, no complaints from plumbers yet).
So far so good. For the shake of insanity, however, I wd like to include a small masking region to break the lines when they cross each other, see attached.
The family is line base, plumbing fitting category, the masking region is not even masking anything inside the family. In project, of course it s done nothing to the effect.
Why, anyone ?
Replies (8)
Message 2 of 9
What's the Masking Region is masking? Symbolic or Model Linework?
Message 3 of 9
RDAOU
@yes_and_no
It is not so very clear what are you trying to mask and where (project vs family) but try a generic annotation with a white filled region
Message 4 of 9
yes_and_no
Symbolic, sub categories as waste, hot, cold, gas, etc...
Message 5 of 9
Message 6 of 9
yes_and_no
Draw in foreground is not the answer, whichever combinations, on the line or on the masking, or both.
I made a quick turn around, it only makes drawing more crowded, attached.
Message 7 of 9
RSomppi
Revit will make those breaks for you if you use MEP hidden lines. Use something larger than 0" for the gap settings.
Message 8 of 9
yes_and_no
Can you elaborate a bit more ?
Message 9 of 9
RDAOU
@yes_and_no
Are you using the system wiring or a line based family?!
  • If the latter please attach for someone to have a look rather than guessing
  • If the former, you can adjust the gaps at crossing wires and the display order for which to be set to front and which to back where the gap applies...ie: no need for masking or additional families (set Discipline to Electrical)
