Inserting 3D DXF file no longer working in Revit 2022
2 ANTWORTEN 2
Nachricht 1 von 3
pmckinleyC75FW
353 Aufrufe, 2 Antworten
Inserting 3D DXF models directly into a project, conceptual mass, or family no longer works for me after upgrading to Revit 2022. The DXF files I am attempting to insert still load with zero issues in Revit 2021, leading me to believe that this is an issue with the updated program, and not the DXF model itself.
With that said, I do (inconsistently) receive an error message when attempting to insert a DXF model:
Revit cannot import some of the geometry. This result can be caused by various issues with the source file. Adjust the geometry in the file and try the import process again.
Has anyone else encountered this issue? If so, is there a work around or solution for importing 3D DXF models?
2 ANTWORTEN 2
Nachricht 2 von 3
syman2000
als Antwort auf: pmckinleyC75FW
Can you upload the DXF file so user can test them out?
Nachricht 3 von 3
pmckinleyC75FW
als Antwort auf: syman2000
Here is an example of the type of DXF file I am trying to insert into my model(s)
