Mapping of Revit Parameters to IFC Parameters for Export
Hello Revit Community!
I want to map the parameters of a heater for a IFC Export.
1. I added the Shared Parameter "IFCExportAS = IfcSpaceHeater"  because otherwise Revit exports Heates as IfcBuildingElementProxy.
2. I created the Family Parameter "Test1" and the Shared Parameter "Test12" (i tested various combinations of shared, instance, family parametes and data types like number and text)
3. Then i use the IFCExport Plugin for the Export: IFC4 Design Transfer View
             In-Session-Setup: Export parameter mapping table
At the end i am not able to get my parameters exported to IFC. I also tried to use built-in parametes like "Comments" etc. to map for an export.
I added to my post some sets of screenshots, so you can check my settings and the used IFC-Classes.
I am keeping this strategy for parameter mapping because it works when i do the same for window parameters.
I also already checked if the problem is, that i have used the "IFCExportAs" Parameter. When i try to export furniture (which Revit exports with the correct Ifc Entity: IfcFurnishingElements) and map some parameters to the property set Pset_condition it doesnt work eiter.
I hope someone can help me and bring some light into the darkness.
Thanks in advance and kind regards
Raymond
Viveka_CD
Hi @Anonymous
Can you share a file to investigate further?
I can send you a private folder link to upload your file.
Looking forward to your reply update.
Hello @Viveka_CD,
thank you. No Problem i can share this date here!
https://we.tl/xsHdjLgYRa
Kind regards,
Raymond
Viveka_CD
Hi @Anonymous
Thanks for sharing your files. The issue is under investigation.
Have you been able to resolve this issue, as I'm having similar problems?
Many thanks,
Mike
