Layer names when exporting a DWG file
manu.seg
Message 1 of 15
manu.seg
I all,
Your help would be greatly appreciated on an issue I have while exporting to DWG.
When I export from Revit all the layers names containing a period ( . ) in my DWG Export Setup is replaced by an underscore ( _ ) when the DWG is created.
See  attached images. Is it possible to keep the period ( . ) in the name? I am supposed to respect a template that I have been given.
Replies (14)
Message 2 of 15
Viveka_CD
Hi @manu.seg
Please see mapping settings for a DWG or DXF export setup
Can you share a file with us to test and the steps you followed so that we can reproduce the issue and investigate further?
I can send you a private folder if you'd like.
Looking forward to your reply update.
Message 3 of 15
manu.seg
Thanks for your quick answer.
My model is 88 mb, so it might be better if you send me a shared folder
link.
Message 4 of 15
Viveka_CD
Hi @manu.seg
I shared an upload link with you.
Let me know if you have trouble accessing the folder.
Message 5 of 15
manu.seg
I created a simplified model to illustrate what I'm talking about.
Here is the Revit and DWG file.
Note the layer name and modifier for WALLS in my DWG export setup and the
name actually exported to Autocad.
Message 6 of 15
Viveka_CD
Hi @manu.seg
Thanks for sharing these files.
I will follow up with an update.
Message 7 of 15
@Viveka_CD, any update on the period exporting layers as an underscore conversion issue?
Message 8 of 15
Viveka_CD
Hi @Anonymous
Thanks for checking in!
I'm sorry that this issue has fallen through the cracks. Let me check back with the dedicated resource and follow up.
Message 9 of 15
Thank you 🙂
Message 10 of 15
Hello @Viveka_CD,
Any update on this?
Thanks!
Message 11 of 15
manu.seg
No, I have sorta gived up, they keep saying they will come back to me on the issue, but nobody does.
Message 12 of 15
Viveka_CD
Hi @Anonymous
Sorry, this is taking so long!
I checked back again with the team working on your issue.
They were able to successfully export without any issues.
They have requested a screencast and the latest journal to investigate further.
Message 13 of 15
Viveka_CD
Hi @manu.seg, @Anonymous
I'm checking again with AutoCAD specialists -
Some ACAD routines don't like specific punctuations (.)  That's why they may be replaced.
Meanwhile here's a forum post that was shared (an article that suggests (.) periods are problematic)
I'll update when I hear more from the team.
Message 14 of 15
Viveka_CD
I wanted to share a recent update -This issue has been identified as legacy bug - I will keep you posted of any progress.
Message 15 of 15
(defun c:Rename_Layer ( / Lay_name)
(vl-load-com)
(vlax-for layer (vla-get-layers (vla-get-activedocument (vlax-get-acad-object)))
   (setq Lay_name (vla-get-name layer))
   (setq Lay_name (vl-string-subst "." "_" Lay_name))
   (vla-put-name layer Lay_name)
is a LISP by @dbhunia that can be run in AutoCAD that changes all underscores in the layer manager to periods - not a solution, but a temporary workaround for the meanwhile.
Thanks @Viveka_CD - highly appreciated!
