making object rotate at its center with parameters
Message 1 of 15
Hi i wold like my model to rotate around its center but i cannot make it so it dose so any ideas. (see attached model and picture)
Replies (14)
Message 2 of 15
hmunsell
why are you nesting a Plumbing Fixture into another Plumb Fixture?
Howard Munsell
Message 3 of 15
i was trying to recenter it without messing up all the reference lines and stuff
Message 4 of 15
I'm with @hmunsell. What's the purpose of this exercise? You are "dumbing" down the component.  Why not load it directly into Project?
...but, if you have to do it, here's how.  See attached.
Message 5 of 15
Mark.Ackerley
This class from Marcello Sgambelluri is a great fun way to learn about easy ways of making things rotate...
https://www.autodesk.com/autodesk-university/class/More-Families-Motion-New-and-Exciting-Methods-Mak...
Whether or not you decide to make this family rotate 🙂
Hope that’s of interest!
Mark
Message 6 of 15
yeah that whole nesting family thing was just to try and change the default center of rotation because when i drew the fitting i did not draw it in the center. But basically i have attached the whole model below and what i wanted is for that 88degree fitting to be able to rotate 360 degrees while being controlled by a parameter and still remaining connected to the U gully (The u  shaped bend)
Hope this clears up some of the confusion
Message 7 of 15
It doesn't really.
Do me a favor; select the "88degreefitting" family in the Project and use Spacebar Rotate on it.  Is the component rotating correctly?  I think not.  Is this what you are trying to correct? The way it rotates?
Message 8 of 15
Yes. I want it to rotate while staying connected to the pipe
Message 9 of 15
-Go to family
-window-select everything
-go to Filters and uncheck everything except Reference Planes
-Under Ref. Planes Properties set "Is Reference" Value to "Not a Reference" for all
-Select the Horizontal and Vertical Ref. Planes intersecting the center point of the fitting, and change their "Is Reference" value to "Strong Reference" and then check "Defines Origin".
-Reload Family into Project
-Re-align fitting
-Test Spacebar Rotate
Message 10 of 15
Thanks mate works perfectly now 😀👍
Message 11 of 15
One more thing I would suggest -- Pin the two "Origin" Ref. Planes and make sure no others are Pinned.
Cheers.
Message 12 of 15
One more thing now that the object rotates properly i want to make it so i can control the rotation with a parameter instead of pushing space bar so i can set it to angles other than ones that are 90 degrees. so to do this i followed this guide (https://aectechtalk.wordpress.com/2010/10/04/keys-to-rotating-items-inside-revit-families/) and got it to work for the majority but when i set it to certain angles like 180 for example it breaks the model. Do you know why this is happening or if there are any other way's to control the rotation so it can be set to a specific angle?
Message 13 of 15
Put a Flip Arrow in Plan View of the Family. If you need to rotate it past 180 degrees in the Project, just Flip the Component.
Message 14 of 15
Are you rebuilding the Family per the example I posted in Message #4?
Message 15 of 15
Got it working. I didn't have 2020 revit installed so i couldn't open the model you sent until today but everything's working all good now. Thanks For the help 🙂
