Making a room ignore a window
SamM6AYEL
SamM6AYEL
I need to create rooms on my balconies for scheduling purposes though unfortunately my model uses Window families as "Structural Openings" in the facade's brickwork. Many balconies project outwards through the structural opening.
I turned the relevant walls to room bounding and the rooms correctly flooded through these windows to form a single room.
However, when I synced, the rooms pinged back and the window started acting as a separator!
Is it possible to get my room to ignore these windows?
vitorbortoncello
hi, split the wall exactly where the window is and uncheck room bounding
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
SamM6AYEL
Thank you, I'm not sure why but splitting the wall above the window seems to have worked, and the room has remained in place after syncing my model to the cloud unlike before.
