Exclude a view from a schedule that is set to "filter by sheet"
2 ANTWORTEN 2
Nachricht 1 von 3
ThijsSchade
203 Aufrufe, 2 Antworten
I want to setup a schedule per sheet that only shows what is on that page. Simple: check on " filter by sheet". But I also have a small floor plan showing which section/elevation are shown on that sheet. This will also be in the schedule.. So also everything that is not on the elevation/sections...
Is theer a way to exclude the small floor plan from being scheduled?
2 ANTWORTEN 2
Nachricht 2 von 3
mhiserZFHXS
als Antwort auf: ThijsSchade
Add another filter that removes that view from the schedule. It could be set up a number of ways.
Nachricht 3 von 3
jay_colcombe
Each View has a Type so you could use a View Schedule and Filter by using the Default Parameter for View Type
Jay Colcombe
Autodesk Certified Instructor
