Make wall thicker to interion
cadedu22
cadedu22
Can't find for such simple task solution, how can I change wall thickness exactly to interion?
I want all extra wall thickness to goo inside interior, not outside, is it possible?
Thanks in advance :).
  • wall
cadedu22
Found solution,
In wall Properties  Change Location Line ( Finish Face Interion - Exterior)
You can also Change an exiting Wall's Orientation by clicking on this symbol.
Also, when placing new Walls, you can use the SPACE Bar to Change the Wall's Orientation.
lucdoucet_msdl
@cadedu22
Glad you found the setting. Here is the explanation: About the Wall Location Line
Hope this helps understand the how and why.
-luc
