Make items visible, but not selectable
HVAC-Novice
Mentor Mentor
HVAC-Novice
I have spaces and they need to be visible to show the space tag.
But when i place, or edit items I always highlight the spaces, which is annoying.
Is there a way to make spaces (or certain families) visible but not selectable? My only workaround is to "pin" a space and "disallow the select pinned elements" . But there is no option to "select all in view" spaces, which makes pinning spaces cumbersome.
Alternatively, is there a way to show the tag of a space, even if it is make not visible? For generic models i can show tags after I hide the generic model families themselves. For spaces the tag disappears when I make the space invisible.
Revit Version: R2026.4.2
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
Put them in a Design Option.
HVAC-Novice
That seems to work. it is similar to my "pin" method. I don't know how warranted this concern is, but if i used design options for actual design options, this will make things complicated.
Is there a way to select one space and then use the "select all..." feature?
@HVAC-Novice wrote:
That seems to work.
What seems to work? An MEP Space in a Design Option?
SteveKStafford
Select everything and use the Filter to only select the Spaces.
Steve Stafford
Create a Space schedule, group all in one row, select that row then switch to a model view and pin.
HVAC-Novice
thanks to all.
My workaround will be "selecting everything" and filtering spaces and pin them. then make pinned elements not selectable.
