Make dependant sections appear on plans as one section without parts
Marcus.Isacsson
Marcus.Isacsson
Hi fellas!
We would like to "fool" Revit into showing only a "B" instead of  "SECTION B - PART 1" & "SECTION B - PART 2" on our plans. Short names without their parts.
Is this somehow possible? We can't have the same view name on the parts ("B"). They're done as a main section with dependant views (on sheet they have to appear on top or beneath each other to fit)
Final lookFinal look
L.Maas
Have you looked at using the "Title on Sheet" parameter?
Louis
Please mention Revit version, especially when uploading Revit files.
Marcus.Isacsson
Can I use "Title on sheet" on the section symbols in our plan views?
That's where our problem lies.
hmunsell
would you be able to use Reference Other view option to place sections in different dependent views but they both point to the same section.
Howard Munsell
L.Maas
I might be misunderstanding you. But is that not what I show in my screenshot?  You see on the sheet two views both named B. So both the same name and only the letter B.
Louis
Marcus.Isacsson
The views aren't the real problem. We want the actual sections to show "B" on our plans (get rid of parts in the naming).
Two sections both showing B. Instead of "B1" & "B2" or similar.
I only get those labels inside the section family so I guess it's not possible?
LabelsLabels
Marcus.Isacsson
I guess this could be one way of doing it... could be a bit tricky if sections are being moved though...
