How to copy VG sets to multiple views
Goodmorning, I would ask how to copy (or import) the VG property' settings of a single view (ex. plan 0) into the other levels (ex plan 1, 2 ...) without set it and do it everytime repeatly. Is there a way to import that kind of visualizations settings to all views? Thank you very much
L.Maas
Have a look at view templates. That is what they are for. The nice thing is you can even create them in you project template already. You can set up a view with all the settings you want and then based on those settings create a view template which you can assign to other views. See HERE for more information on View Templates
Louis
Please mention Revit version, especially when uploading Revit files.
MostafaElashmawy
From View tab, click on view template then choose create template from current view. Give it a name and ok twice.
In the other view, click on view template then choose apply template properties to current view. Then choose the template that you've just created.
You can apply the template also from the properties of the view.
Mostafa Elashmawy
