Hi folks,
Somewhat new to the admin-side of Autodesk stacks, so please bear with me.
I'm competently comfortable with IC Systems architecture, but my knowledge of what folks do inside the apps is a little light; I care how my charges use tech, not the actual data. (data's just data as far as I'm concerned)
This is a relatively greenfields setup spun up on a shoestring, but we're coming up on the limits of that budget (or lack thereof), and so scaling up & out a bit.
Up to this point & between phases of our local COVID lock-downs, the practice has been mostly OK using Google drive, but that's not appropriate anymore. (long story)
There's now momentum to get set up better & with a little more deliberate forethought & planning so that the tech stack capacity & capability can grow as resources allow.
Besides budgets, there are other constraints in play, including unpredictably random periods of imposed remote-work and general spotty connectivity.
That being said, what we have now:
Users seem to be using Revit 2020-22, but not making use of BIM Collaborate due to costs.
Presently still using G'Apps/suite on the collaboration & doc-side, but moving to o365/Sharepoint/Azure stack, as that's what the majority of clients are communicating with us with, and offers a number of benefits in order to consolidate functionality fragmented across other solutions or integrations/automations where possible.
Will probably be using Azure-AD for GPO, etc.
VPN connectivity is pretty stable, with Central syncing seeming to perform OK so far.
Given the above...:
I'd like to find or develop a good remote-local-cloud hybrid model to make the process more seamless & scalable.
Ensure that the authoritative "A Single Source of Truth" (SSoT?) be the in-house NAS, and ensure sync is managed & maintained across various platforms.
In particular, I'd like to figure out some sort of mechanism that would maintain the current dataset of the active projects across nodes, so I need a means of ensuring that BIM data is safeguarded for those users that get licences/subscriptions.
Either syncing BIM with Azure/SP/o365 or with the NAS.
I'm able to spin up a Docker container to host an agent on the NAS, or some other service/app on o365 I can sync with.
Alternatively/additionally, some sort of client-side agent that will maintain a local cached copy of the remote works so that a current copy is always current & available & the principal (central?) dataset is kept updated with changes, rather than users having to constantly pause to sync & disrupt their momentum & flow.
If there's some sort of version-control I can hook into a GIT server (local or hosted), that'll be pretty cool.
Until there's a clear & deliberate need or benefit to fork out for additional Autodesk tech (I'm sure it'll arise) we'd like to make use of the very extensive MS solutions already available to us, which will replicate some of this tech being upsold.
(Guessing that's where Forge API comes in handy)
It is possible but first read this article on Revit interoperability with network (NAS / SAN) and cloud file storage. I will give you a brief idea on what you are up against https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Then I would suggest that you close out this post...and post more particular question on the Installation Forum HERE https://forums.autodesk.com/t5/installation-licensing/bd-p/24. General questions on setting up the whole network infrastructure are less likely to get many hits with overall solutions
