- Mute
- Permalink
- Report
Now being a dedicated ACAD user and starting to add Revit LT to the mix means I am getting pretty frustrated with complex problems which seem to result out of simple issues. like trying to work out how to get windows to show up under the cut plane. I have used this example attached as its not really a visibility thing or a setting issues as I have used a new default project and shown low walls up to the cut plane and they all show.
BUT, no matter what I do, what tutorial I watch or what measurements I put into Veiw Range that little window will never show up on the ground floor plan (or whatever level its in).; they are clearly on the 3d view.
I have seen complex attempts to explain this which normally end up getting me to a tab or drop down menu that does not exist. I do not need a machine level programming answer, surely this is simple and easy.
surely this is a simple problem as its one of the most basic needs of revit, why this has to be so complicated I will never understand.
please help. (oh and I requested a phone contact but they never called me)
Darren
