Looking for possibilities to check properties of Components in Navisworks.
BalajiHTI
BalajiHTI
I am not sure whether This post belongs here or in the Navisworks board or whether it is asked before. Anyway since the models are created in Revit, I will ask here.
I have couple of files as Revit Models. They have parametric family elements of all categories. I am planning to check whether all the elements have certain instance and type parameter property valvues in its correct form.
For example, lets say every object has an instance called XYZ and the value for the parameter should be in this format: "ABC-LKJ".
Is there any way to check their correctness in an Exported NWC File loaded in Navisworks Manage?
I am using Revit 2015 (BDSU - One Box) and Navisworks Simulate 2015 & Navisworks Manage 2014.
Any level of advice is welcome. Thanks in advance.
Spoiler
Smiley Happy
ennujozlagam
hi,
Yes, just use find and select by using the parameter in Revit.
http://knowledge.autodesk.com/support/navisworks-products/learn-explore/caas/CloudHelp/cloudhelp/201...
hope it helps. thanks
