looking for a window family with division
danezeq
Message 1 of 11
danezeq
i'm looking for a certain window family on revit which has a fixed glass division on the bottom (pic1), while the upper glass can be opened in two modes like pic2
does anyone know if it's possible to find one?
PIC1PIC1PIC2PIC2
Replies (10)
Message 2 of 11
Why don't you just nest both types into a host, and call it what you want? Revit has both, OOTB.
Message 3 of 11
Corsten.Au
Hi
try to create a new family with panels hosted.
bit of family creation here..
Cannot share the window family though..
but would highly recommend to create one for your unique requirement.
Cheers..
Corsten
Building Designer
Message 4 of 11
danezeq
I really don't know how to create and edit families. Is there any window family like that on any BIM site?
Message 5 of 11
chrisplyler
 You're going to have to learn to make your own families in Revit sooner or later.
Edited by
Discussion_Admin
Message 6 of 11
danezeq
What do you mean by "nest both types into a host"? do you talk about a curtain panel with two different panels?
Message 7 of 11
I didn't say anything about "curtain panel with two different panels"; primarily because you never mentioned "curtain panel". Also, if you don't know how to create/edit Revit families, I can't be of much further help to you.  Good luck.
Message 8 of 11
Sahay_R
Learn how to create Revit families. You will make yourself so much more valuable.
For  starters - open an OOTB window family. Study it. Save a copy of it. Tweak it to do what you need it to. If you run into a snag, post for help. Posts which indicate that you have run into a snag while in the process get better responses, all from the goodness of our hearts.
To search for something that works - try BIM Object or ARCAT.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 9 of 11
danezeq
Thanks. what does "OOTB window" means?
Message 10 of 11
danezeq
Message 11 of 11
Viveka_CD
Hi @danezeq
Thank you for posting on our forum! Smiley Happy
  • You can also take a look at BIM Objects to filter windows products
  • Please use the Family Editor to make changes to existing families or to create new families.
  • See the following steps to create a simple parametric family in Revit  for a Window.
  • See the tutorial HERE to create a simple Revit Window Family.
Please don't hesitate to reach out if you have additional questions and we are happy to help!
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions. Kudos welcome.
