WARNING: None of the created elements are visible in floor plan
Revit Architecture 2017 I receive the following warning:
None of the created elements are visible in Floor Plan: ENLARGED MAIN LEVEL-A View. You may want to check the active view, its Parameters, and Visibility settings, as well as any Plan Regions and their settings.
This comes after I have tagged walls.  I can see the tags on the plans, don't know if this is being left out elsewhere?!
Should I be concerned?
Tags only appear on the View where you tagged them.  If you intended to tag the walls and you can see the wall tags just fine then nothing to worry about.
It could be you accidentally picked a floor or something else then the tag of that category was turned off.
