Are you the author? is there a TOC or more information? There was no " Look inside" option. I'm wondering if those 2 books would be redundant to the ones I suggested above, or would have additional information/methods. We have a few new people supposed to learn Revit and I wonder if they would help.
One somewhat frustrating experience from learning from books was that multiple books have a LOT of redundant information. Many books also waste a lot of space on things that already should be clear. Like how a computer works, or how to install Revit. that easily could be skipped and if needed found elsewhere.
Also check out Balkan Architect on YT.
OP: if you can, I would recommend switching to R2024 and buying books for R2024. R2024 introduced some minor UI changes and the screenshots in the books will be less confusing if you use the exact same version.
Without that UI change, it generally OK to learn with a 5 year old book, though. The user may miss some new features, but typically no deal breaker for a newby. I suspect the Books that have a 2018 and a 2019 version, for example, are just re-prints and changed did a find-and-replace to turn 2018 into 2019 any actual change. A 2012 book would be quite a stretch, though.
If you include Dynamo, there are only about 6 books you ever will need and the rest is all online. Books basically give you a somewhat structured start.
Revit Version: R2026.4
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
