loft function does not work well
denis_kraenert
denis_kraenert
In ACAD I can loft following 2 section easy. Revit produce different result with same function. How to get the same result in Revit. Picture: left import from ACAD, right result loft function in Revit.
Are you in a massing environment? You might get a better result using a sweep blend in a "regular" environment.
In-Place Component Sweep Blend:
loboarch
Could you give us an image of the 2 (or multiple profiles) you are using in Revit to loft the form?  Or even better a file that has the form, and a copy of the profiles you are using. With that it might be easier to troubleshoot exactly what might be happening. ACAD and Revit should produce the same form using the same profiles.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
denis_kraenert
I solved the issue by using 2 halfes. Then blend function works fine.
loboarch
Glad you resolved it. Thanks for the image illustrating.
Jeff Hanson
Revit Help |
