I sometimes have problem in family editor: extrusion is locked to a reference plane (it's start and end) and I am unable to unlock it - either by changing values of the extrusion, by dragging of it's handles or by finding the lock icon. It can be solved by deleting unrelated geometry - like some other extrusion or even detail lines. I make sure the extrusion is locked to reference planes, not other geometry. See attached video, it's hard to describe by text. Does anyone have an idea for the reason of this behavior?
See video here:
Tom
Solved by ToanDN. Go to Solution.
Would you want to share the family to check it?
Reveal Constraints > select the purple reference planes constraining the extrusion and unlock their pad locks. Then you will have no problems stretching the extrusion.
