Lock two text boxes in title block
hamed_handsome
Message 1 of 8
hamed_handsome
Is there any way to lock a label to another so that when the top label has multiple lines it pushes the other label down accordingly?
Thanks for your help
Replies (7)
Message 2 of 8
Yes.
Message 3 of 8
lucdoucet_msdl
@hamed_handsome
Rather than think of it as two labels affecting each other, you can combine two parameters into a single label with a line break between the two parameters. See the Breakline option in the help link below.
-luc
https://help.autodesk.com/view/RVT/2020/ENU/?guid=GUID-4CCEF31F-FC5F-46DE-9600-339CA4163640
Message 4 of 8
hamed_handsome
Thank you for your reply. They have two different font sizes, that's why I can't put both in one label.
Message 5 of 8
_Vijay
Then you better use two labels..
Vijayakumar
Head of BIM
Did you find this post helpful? Feel free to like this post.
Message 6 of 8
Set Top one to Bottom Align. Set bottom one to Top Align.
Message 7 of 8
hamed_handsome
Not Exactly what I asked but it does the job. Thanks.
Message 8 of 8
hamed_handsome
I ended up leaving the top label where it should be ( client name) and added 4 text boxes with the same label beneath that (Client Address) with different font. Then added a parameter so that if the upper text box has let's say 2 lines, the second text will be visible if it has three lines the third one, and so on. People need to adjust the parameter manually on the title block.
