Realistic Elevations - Window Transparency
12 ANTWORTEN 12
GELÖST
Nachricht 1 von 13
zeulrick
4678 Aufrufe, 12 Antworten
Anyone know a quick hack to give glass a nice shaded color that is VISIBLE in realistic views and prevents objects from showing behind it?
Please note that I have tried all the simple solutions available in the material browser. I have also tried overriding the graphics.
12 ANTWORTEN 12
Nachricht 2 von 13
als Antwort auf: zeulrick
Nachricht 3 von 13
zeulrick
als Antwort auf: ToanDN
Realistic View Yo!
Nachricht 4 von 13
zeulrick
Here is a screen shot. I can't figure out how the two windows on the left and right appear this way. I would like them all to have that appearance.
Nachricht 5 von 13
zeulrick
Are you able to see objects behind those windows?
Nachricht 6 von 13
Nachricht 7 von 13
No. You cannot see through window glass on an elevation, only 3D.
Nachricht 8 von 13
zeulrick
I can always see through window glass in 2d realistic elevations...as you can see from my screenshot. Revit Update with 2021?
Nachricht 9 von 13
martijn_pater
Seems like a rvt21 update. If the family opening cut is checked for elevation transparency in the family it will now also show in realistic mode as see-through, depending on the glass material ofcourse. For transparency with other visual styles you would uncheck the glass' subcategory.
Nachricht 10 von 13
noconnorG728Y
We used this colour for glass
218/227/214.
The standard Revit glass colour are ugly.....
Nachricht 11 von 13
martijn_pater
als Antwort auf: martijn_pater
@martijn_pater wrote:
If the family opening cut is checked for elevation transparency in the family...
So actually your answer would be to edit the family, select the opening cut and uncheck the transparency for elevations.
Nachricht 12 von 13
zeulrick
Nice Job, thank you! This works for some of my families. Some, however, don't have opening cuts, they have void extrusions. What do I do for those?
Nachricht 13 von 13
martijn_pater
I suppose you could nest them into a family that does or place a family with non-transparent opening cut behind it?
