Sharing Models Remotely
10 ANTWORTEN 10
GELÖST
Nachricht 1 von 11
975 Aufrufe, 10 Antworten
I am an experienced Revit user but am at a loss when trying to set up our office for remote model sharing. We have been lucky enough to make it this far without it but now, on a larger project, it is very necessary for the entire team to be in one model. I have set up Autodesk Drive but that does not seem to allow us to all work on one model simultaneously. I have researched 360 but as I'm sure you can understand, am struggling to explain to the higher ups why we now need another $900 a year on top of the already expensive subscription. What is everyone else doing? How are you linking local models and central files remotely? -Thanks
10 ANTWORTEN 10
Nachricht 2 von 11
RobDraw
als Antwort auf: Anonymous
BIM 360 is the only live option as far as I know.
Rob
Nachricht 3 von 11
syman2000
Remote Desktop works as well. BIM360 work seamlessly.
Nachricht 4 von 11
RobDraw
If everyone is on the same network, remote desktop might be a better solution. When I read your post, somehow I got the impression that people would be on different networks. My mistake.
Rob
Nachricht 5 von 11
hmunsell
we have 70% of our office (400-500 people) working from home.  they all VPN connect to our network and use Remote Desktop from there home PC to remote into there office PC. Once they are on their office PC it is just like working in the office. some have even said Revit runs faster when there remoted in.
Howard Munsell
Nachricht 6 von 11
baker
als Antwort auf: RobDraw
I was afraid of that. Appreciate the response. -C
Nachricht 7 von 11
baker
als Antwort auf: syman2000
Appreciate it! -C
Nachricht 8 von 11
baker
No worries. I appreciate the feedback! -C
Nachricht 9 von 11
baker
als Antwort auf: hmunsell
Thanks for the info. It is greatly appreciated -C
Nachricht 10 von 11
Nachricht 11 von 11
Lance.Coffey
Thank you for the question @Anonymous!
Posting some additional info on this topic for reference. The following Revit Blog post has more details on these options (Cloud Worksharing / Remote Desktop): Remote working with Revit
The linked article (from the blog above) Options for Remote Access in Revit has more options (Revit Server / Citrix).
If your users have systems in the office, then Remote Desktop (or some other remote access solution) as @syman2000 mentioned would probably be the easiest option.
However, if your users are working with systems (most commonly laptops) which they’ve taken home (i.e. no user systems in the office), then this will not work as well.
    Some things to keep in mind when considering Revit Server:
  • Revit Server’s design intent was to extend worksharing workflows to work between offices within a single company.
  • The normal setup would have an Accelerator (running on a Windows file server) in each office to improve local model creation and synchronize times.
  • However, as Accelerator is not required it would be possible for users to connect to the office network and work with the Revit Server models (they may see reduced performance on synchronize and create local operations due to the lack of an Accelerator).
  • Revit Server is a MS IIS application server, which requires familiarity with IIS, and additional IT maintenance / overhead compared to file-based worksharing or cloud worksharing.
Note: If possible, I would suggest avoiding the use of File-based worksharing (the regular type, that isn’t Revit Server or Cloud worksharing) across an Internet/WAN connection as it isn’t designed for this environment and doesn’t have the necessary protections put in place (like Revit Server or Cloud Worksharing) to prevent corruption or loss of data when there are network hang-ups or interruptions.
Lance Coffey
Technical Support Specialist
