Lock Element in Family 3D view
hliS658H
Message 1 of 23
hliS658H
I need to lock the edges of the panels to the lower support edges like the most front panel, so they can move along with them . Due to the visibility issue, I do the alignment  in 3D view, however, the lock doesn't show up. Is there a way to do this?
Replies (22)
Message 21 of 23
hliS658H
Here is the screenshot of my model, I set the workplane for each panel (following your advice) then lock the lower edge of the panel to the support's edge without adding extra reference plane/line. What do you think of this approach?
Message 22 of 23
I think it's no good.
If the above reply answers your question, please mark this post as an "Accepted Solution" -- and a "Like" (optional).
Message 23 of 23
lim.wendy
Hi @hliS658H,
Thanks for reaching out to the forum. Have you had a chance to look over the suggestions provided by our experts?
Do you have any questions about it, let us know if you require further assistance.
If the suggestions helped you, please hit the "Accept Solution" button, as it helps make the solution easier to find for others who might have the same issue. Knowing which topics are solved or not can also help our many users find the questions that still need to be answered. It’s also a great way to say thank you and give recognition to whoever helped you. ?
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
