Load Level Head Family
PhilvK
PhilvK
After opening the Level Head Family file “Level Head – Target.rfa”, I click “Load Into Project”.  It says that this family will be automatically loaded into any open project, however when I go to the open project, it does not appear as an available type. How do you get different types of Level Heads to be available to choose from please?
Replies (10)
cbcarch
In the Browser, Annotation Families, scroll down to Level Heads--it should be there. If not, it did not get loaded correctly into the Project.
See attached.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
PhilvK
Cliff - It is listed, but I don' know how to get where I can select it to be the type I want to use. I am very new to this.
Thanks - Phil
cbcarch
Go to an Elevation or Section. Click on the Level Head--then under Properties, change the Type.
Cliff B. Collins
PhilvK
The style I want to change to doesn't appear in the list under "Edit Type". It does however appear under Families in the Project Browser.
Phil
cbcarch
Select one that is loaded, under Properties, choose Duplicate. Then Edit Type. Select the desired Type from the drop down list.
Does it work?
Cliff B. Collins
PhilvK
Thank you, I will try this, but I was just trying to be able load one that is laready been made a family.
Wow, this thread was written back in 2014, but I had the same problem, and just found a solution.
We have to change the "Symbol" under "Type Properties".
Benjamin.Schebella
same problem for me except i've loaded it into the project, and it still won't come up as an option when i select symbol type in edit type window for the level head.
bojannaneski
This is solution
thx
jsrlrpc
THANK YOU!!!!
