Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Load bearing wall in Revit Architecture
Hi everybody
I need a clarification: I'm modelling a load-bearing masonry wall in the Revit Architecture and Structural.
I'm sure that in the Revit structural I have to choose "structural wall", but in the Revit Architecture should I choose "architectural wall" or "structural wall"?
I thought that I have to choose "structural wall" in Revit Architecture and Structural both; what do you think?
Walls have a "Structural" Parameter under their Instance Properties. Check it and pick a "Structural Usage".
FWIW:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2020/EN...
It is clear! Thank you @barthbradley
