Revit Area Schedule does not populate
twiggallemore
Message 1 of 9
twiggallemore
I have not been able to get an area schedule to populate. I created the area plan, then I created New Schedule/Quantities and select Category: Areas (Gross Building) then confirm Schedule Building Components is checked , then select the scheduled fields I want to see and select ok--The schedule does not display any of the areas on the area plan. I confirmed the areas are tagged and fully enclosed. I confirmed that no filters are set.  The problem seems to be happening only on this project file--my area plans and schedules in other projects are scheduling fine.  Could the file have become damaged or is there some visibility setting I am not seeing?
Replies (8)
Message 2 of 9
syman2000
Can you upload the file sample so we can take look?
Message 3 of 9
Check phasing of area plan and area schedule. They should match.
Message 4 of 9
Maybe you selected the wrong Areas to Schedule?  That would be my first guess.
Message 5 of 9
ahmadfiroozi000
When you select Area you must select in type bar (Gross Building) then ask you external walls and you select yes
Message 6 of 9
twiggallemore
Thanks, I don't think areas /area schedules can be phased. (I checked all phases of the area plan views)
Message 7 of 9
twiggallemore
Thanks, I don't think you select areas to schedule, but I did verify that no filters are set in the schedule
Message 8 of 9
twiggallemore
Thanks I tried this also both rentable and gross area, even tried to use custom area types. Then I saw a post on another blog about cache/corrupt file problems so I deleted all temp cache files and restarted and it finally started working as expected. (The project file is a large multiphased project with several linked files) Not sure exactly what was causing the problem but it seems to be fixed and back to working as expected. Thank you everyone for the help.
Message 9 of 9
lamquangvietthinh
THIS SAVED ME FORM THE RING OF DEAD !!!!
