List of sheets in multiple Revit Projects
LyleHardin
Advisor Advisor
LyleHardin
I'm looking for a way to find or list all the sheets in a large project which is comprised of several Revit models.
We have several structures in this project. Each structure is made of 1-3 Revit models from different disciplines (Structural, Electrical, Piping, etc.). So, we have about a dozen Revit models and each has their own set of sheets.
Is there an easy/quick way to list all sheets from all those models without opening each one and looking at the sheet schedule?
L.Maas
Dynamo could be a solution. Hereunder a concept
Louis
Please mention Revit version, especially when uploading Revit files.
LyleHardin
Well then, looks like a good time to get into Dynamo!
I kinda figured Dynamo would be one solution.
I've had a few false starts learning Dynamo in the past, but I'll give it another go.
Thanks for the code suggestion, I'll give it a whirl!
L.Maas
Definitely give it a try. You will see when you get comfortable with it that you will use it more and more.
There is good information on dynamobim.org (tutorials and good forum).
As a note the "get all elements from linked file"is from an additional package named archilab (can be downloaded from within Dynamo)
Louis
