List of Default Families Available
In the process of learning Revit LT, I rediscovered the old MSDOS Tree command and created a list of the default "Families". I figure its important to know where all the various Families are in the convoluted structure of the default library. It runs 11 pages, small text and lists all the .rfa files. For "conventional" U.S. units, not metric. Tried to upload it to the forum, but the post doesn't seem to go through. About 1/2 a meg in size.
Its in a .rtf format to avoid potential malware.  Hoped it might it help folks navigate families and learn the program.
MSDOS!? Why not just drill down into the Library Folder using this new-fangled Windows UI.
MS-DOS (or Windows Power Shell) has the TREE command.
Because Windows only allows me to see a dozen or so items at a time. There are probably a thousand families listed, but its difficult to understand the context of their relationships with such a small snapshot. Besides I can mark up a list by hand much easier. Listing the limitations of height on certain doors for instance. This might be an LT only thing btw.
 "Listing the limitations of height on certain doors for instance"? What do you mean by this?  What kind of information is in this tree?  Does it list all the  TYPES and PARAMETERS within each family?
Ha ha, no, you have to add that yourself of course.
In our case we use a lot of 8' high interior doors, so doors that can't be set that high are pretty much useless to us.
partial list:
Revit Family Files from Library
18 06-25-18 File Tree.doc ================================================================= ...RevitKeynotes_Imperial.txt ...RevitKeynotes_Imperial_2004.txt ...RevitKeynotes_Imperial_2010.txt ...Section Tail - Upgrade.rfa ...UniformatClassifications.txt ...UniformatClassifications_2010.txt ... ....Annotations ......Callout Head w Sheet-Ref Sheet.rfa ......Callout Head.rfa ......Centerline.rfa ......Detail Item Tag.rfa ......Elevation Mark Body_Circle.rfa ......Elevation Mark Body_Custom.rfa ......Elevation Mark Body_NCS.rfa ......Elevation Mark Body_Square.rfa ......Generic Model Element Tag.rfa ......Graphic Scale1-4.rfa ......Graphic Scale1-8.rfa ......Grid Head - Circle.rfa ......Grid Head - Hexagon.rfa ......Grid Head - No Bubble.rfa ......Grid Head - Square.rfa ......Keynote Tag.rfa ......Label Annotation 1-16.rfa ......Label Annotation 1-8.rfa ......Label Annotation 3-32.rfa ......Level Head - Circle.rfa ......Level Head - No Bubble.rfa ......Level Head - Square.rfa ......Level Head - Target.rfa ......Level Head - Triangle.rfa ......Multi Category Tag.rfa ......North Arrow 1.rfa ......Revision Tag.rfa ......Room Tag.rfa ......Section Head - 1 point Filled.rfa ......Section Head - 1 point Open.rfa ......Section Head - Circle w Sheet-Ref Sheet.rfa ......Section Head - Filled w Name.rfa ......Section Head - Filled w Sheet-Ref Sheet.rfa ......Section Head - Filled.rfa ......Section Head - no arrow.rfa ......Section Head - Open.rfa ......Section Tail - Filled Horizontal.rfa ......Section Tail - Filled.rfa ......Section Tail - Open Horizontal.rfa ......Section Tail - Open.rfa ......Spot Elevation - Circle w Crosshair.rfa ......Spot Elevation - Crosshair.rfa ......Spot Elevation - Target Filled w Extension.rfa ......Spot Elevation - Target Filled.rfa ......Spot Elevation - Target.rfa ......View Reference.rfa ......View Title - Square w Sheet-Ref Sheet.rfa ......View Title - Square w Sheet.rfa ......View Title w Sheet-Ref Sheet.rfa ......View Title w Sheet.rfa ......View Title-No Bubble w Sheet-Ref Sheet.rfa ......View Title-No Head.rfa ......View Title.rfa ......Window Tag - Multi Category.rfa ...... .......Architectural ...... Casework Tag.rfa ...... Ceiling Tag w Height.rfa ...... Ceiling Tag.rfa ...... Curtain Panel Tag.rfa ...... Door Tag.rfa ...... Floor Tag.rfa ...... Furniture Tag.rfa ...... Material Tag.rfa ...... Railing Tag.rfa ...... Specialty Equipment Tag.rfa ...... Stair Landing Tag.rfa ...... Stair Run Tag.rfa ...... Stair Support Tag.rfa ...... Stair Tag.rfa ...... Wall Tag.rfa ...... Window Tag - Number.rfa ...... Window Tag MRA.rfa ...... Window Tag.rfa ...... .......Civil ...... Parking Tag.rfa ...... Planting Tag.rfa ...... Property Line Tag-Radius.rfa ...... Property Line Tag.rfa ...... Property Tag - Acres.rfa ...... Property Tag - SF.rfa ...... .......Electrical ...... Electrical Equipment Tag.rfa ...... Electrical Fixture Tag.rfa ...... Lighting Fixture Tag.rfa ....... .......Mechanical ...... Mechanical Equipment Set Tag.rfa ...... Mechanical Equipment Tag.rfa ...... Plumbing Fixture Tag.rfa ...... .......Structural ... Structural Column Tag-45.rfa ... Structural Column Tag.rfa ... Structural Foundation Tag with Elevation.rfa ... Structural Foundation Tag.rfa ... Structural Framing Tag-w-Joist Girder.rfa ... Structural Framing Tag.rfa ... ....Casework .......Base Cabinets ...... Base Cabinet-2 Bin.rfa ...... Base Cabinet-4 Drawers.rfa ...... Base Cabinet-Built In.rfa ...... Base Cabinet-Corner Unit-Angled.rfa ...... Base Cabinet-Double Door & 2 Drawer.rfa ...... Base Cabinet-Double Door Sink Unit.rfa ...... Base Cabinet-Filler.rfa ...... Base Cabinet-Single Door & Drawer.rfa ...... Base Cabinet-Single Door w Sliding Drawers.rfa ...... Base Cabinet-Single Door.rfa ...... Vanity Cabinet-Double Door & 4 Drawer.rfa ...... Vanity Cabinet-Double Door Sink Unit.rfa ...... Vanity Cabinet-Single Door & Drawer.rfa ...... Vanity Cabinet-Single Door.rfa ...... .......Counter Tops ...... Counter Top w Sink Hole.rfa ...... Counter Top w Sink.rfa ...... Counter Top-Island w Sink Hole.rfa ...... Counter Top-Island.rfa ...... Counter Top-L Shaped 2.rfa ...... Counter Top-L Shaped w Sink Hole 2.rfa ...... Counter Top-L Shaped w Sink Hole.rfa ...... Counter Top-L Shaped w Sink.rfa ...... Counter Top-L Shaped.rfa ...... Counter Top.rfa ...... Vanity Counter Top w Round Sink Hole.rfa ...... Vanity Counter Top w Square Sink Hole.rfa ...... .......Shelving ...... Closet Shelf and Pole.rfa ...... .......Tall Cabinets ...... Tall Cabinet-2 Door-Built in.rfa ...... Tall Cabinet-Double Door(4).rfa ...... Tall Cabinet-Single Door(2).rfa ...... .......Wall Cabinets ... Upper Cabinet-Corner Unit Tall 1-Wall.rfa ... Upper Cabinet-Corner Unit-Wall.rfa ... Upper Cabinet-Double Door w Glass-Wall.rfa ... Upper Cabinet-Double Door-Wall.rfa ... Upper Cabinet-Filler-Wall.rfa ... Upper Cabinet-Single Door w Glass-Wall.rfa ... Upper Cabinet-Single Door-Wall.rfa ... ....Columns ... Chamfered Column.rfa ... Rectangular Column.rfa ... Round Column.rfa ... ....Curtain Wall Panels ... Empty Panel.rfa ... Glazed Panel.rfa ... Solid Panel.rfa ... ....Detail Items .......Div 01-General ...... Break Line.rfa ...... .......Div 03-Concrete ..........031500-Concrete Accessories ......... Water Stop-Bulb Dumbbell-Section.rfa ......... Water Stop-Bulb Serrated-Section.rfa ......... Water Stop-Dumbbell-Section.rfa ......... Water Stop-Serrated-Section.rfa ......... ..........032100-Reinforcing Steel ......... Reinf Bar Bend 3-8.rfa ......... Reinf Bar Bend 9-11.rfa ......... Reinf Bar Elevation.rfa ......... Reinf Bar Section.rfa ......... ..........033100-Structural Concrete ......... Concrete Beams-Section.rfa ......... Concrete Beams-Side.rfa ......... Concrete Beams-Top.rfa ......... Concrete Columns-Circular-Side.rfa ......... Concrete Columns-Circular-Top.rfa ......... Concrete Columns-Rectangular-Side.rfa ......... Concrete Columns-Rectangular-Top.rfa ......... Concrete Footing-Rectangular-Section.rfa ......... Concrete Footing-Rectangular-Side.rfa ......... Concrete Footing-Rectangular-Top.rfa ......... Double Tee Joist-Section.rfa ......... Double Tee Joist-Side.rfa ......... Double Tee Joist-Top.rfa ......... Slab Beams-Section.rfa ......... Slab Beams-Side.rfa ......... Slab Beams-Top.rfa ......... Slab with Optional Haunch-Section.rfa ......... Slab with Optional Haunch-Top.rfa ......... Strip Footings-Section.rfa ......... Strip Footings-Side.rfa ......... Strip Footings-Top.rfa ......... ..........034100-Precast Structural Concrete ......... Precast Beams-Inverted Tee-Section.rfa ......... Precast Beams-Inverted Tee-Side.rfa ......... Precast Beams-Inverted Tee-Top.rfa ......... Precast Beams-L Shaped-Section.rfa ......... Precast Beams-L Shaped-Side.rfa ......... Precast Beams-L Shaped-Top.rfa ......... Precast Beams-Rectangular-Section.rfa ......... Precast Beams-Rectangular-Side.rfa ......... Precast Beams-Rectangular-Top.rfa ......... Precast Columns-Rectangular-Section.rfa ......... Precast Columns-Rectangular-Side.rfa ......... Precast Slab-Hollow Core-Section.rfa ......... Precast Slab-Hollow Core-Side.rfa ......... Precast Slab-Hollow Core-Top.rfa ......... Precast Solid Flat Slab-Side.rfa ......... Precast Solid Flat Slab-Top.rfa ......... Precast Solid Flat-Section.rfa ......... Precast Stemmed Deck Members-Double Tee-Section.rfa ......... Precast Stemmed Deck Members-Double Tee-Side.rfa ......... Precast Stemmed Deck Members-Double Tee-Top.rfa ......... Precast Stemmed Deck Members-Single Tee-Section.rfa ......... Precast Stemmed Deck Members-Single Tee-Side.rfa ......... Precast Stemmed Deck Members-Single Tee-Top.rfa ......... ..........035300-Concrete Topping ......... Concrete Topping Slabs-Section.rfa ......... ..........035400-Cast Underlayment ...... Gypsum Topping-Section.rfa ...... .......Div 04-Masonry ..........040500-Common Work Results for Masonry .............040513-Masonry Mortaring ............ Mortar-Section.rfa ............ .............040519-Masonry Anchorage and Reinforcing ............ Bar Column Anchor-Section.rfa ............ Bar Column Anchor-Side.rfa ............ Bar Column Anchor-Top.rfa ............ Bottom Flange Column Anchor-Section.rfa ............ Bottom Flange Column Anchor-Side.rfa ............ Bottom Flange Column Anchor-Top.rfa ............ Corrugated Bar Column Anchor-Section.rfa ............ Corrugated Bar Column Anchor-Side.rfa ............ Corrugated Bar Column Anchor-Top.rfa ............ Corrugated Column Anchor-Section.rfa ............ Corrugated Column Anchor-Side.rfa ............ Corrugated Column Anchor-Top.rfa ............ Corrugated Wall Tie-Section.rfa ............ Corrugated Wall Tie-Side.rfa ............ Corrugated Wall Tie-Top.rfa ............ Dovetail Corrugated Anchor-Section.rfa ............ Dovetail Corrugated Anchor-Side.rfa ............ Dovetail Corrugated Anchor-Top.rfa ............ Pencil Rod-Section.rfa ............ Pencil Rod-Top.rfa ............ Rectangular Tie-Section.rfa ............ Rectangular Tie-Side.rfa ............ Rectangular Tie-Top.rfa ............ Rod and Pintle-Section.rfa ............ Rod and Pintle-Side.rfa ............ Rod and Pintle-Top.rfa ............ Weld on Rod-Section.rfa ............ Weld on Rod-Side.rfa ............ Weld on Rod-Top.rfa ............ Wire Column Anchor-Section.rfa ............ Wire Column Anchor-Side.rfa ............ Wire Column Anchor-Top.rfa ............ Z Tie-Section.rfa ............ Z Tie-Side.rfa ............ Z Tie-Top.rfa ............ .............040523-Masonry Accessories ......... PVC Control Joint-Top.rfa ......... PVC Sash Block Joint-Top.rfa ......... PVC Sash Block Tee-Top.rfa ......... Rubber Control Joint-Top.rfa ......... Rubber Sash Block Joint-Top.rfa ......... Rubber Sash Block Tee-Top.rfa ......... ..........042000-Unit Masonry ......... Stone Panel-Section.rfa ......... Stone Quoin-Side.rfa ......... ..........042100-Clay Unit Masonry ......... Bricks-Section.rfa ......... Bricks-Side.rfa ......... Bricks-Top.rfa ......... ..........042200-Concrete Unit Masonry ......... Bond Beams-Double-Section.rfa ......... Bond Beams-Double-Side.rfa ......... Bond Beams-Double-Top.rfa ......... Bond Beams-Single-Section.rfa ......... Bond Beams-Single-Side.rfa ......... Bond Beams-Single-Top.rfa ......... CMU-2 Core-Section.rfa ......... CMU-2 Core-Side.rfa ......... CMU-2 Core-Top.rfa ......... CMU-3 Core-Section.rfa ......... CMU-3 Core-Side.rfa ......... CMU-3 Core-Top.rfa ......... Fluted CMU-4 Flutes-Section.rfa ......... Fluted CMU-4 Flutes-Side.rfa ......... Fluted CMU-4 Flutes-Top.rfa ......... Fluted CMU-8 Flutes-Section.rfa ......... Fluted CMU-8 Flutes-Side.rfa ......... Fluted CMU-8 Flutes-Top.rfa ......... Glazed Face CMU-Section.rfa ......... Glazed Face CMU-Side.rfa ......... Glazed Face CMU-Top.rfa ......... Ground Face CMU-Section.rfa ......... Ground Face CMU-Side.rfa ......... Ground Face CMU-Top.rfa ......... Round Fluted CMU-Section.rfa ......... Round Fluted CMU-Side.rfa ......... Round Fluted CMU-Top.rfa ......... Scored CMU-Section.rfa ......... Scored CMU-Side.rfa ......... Scored CMU-Top.rfa ......... Shaped Sill CMU-Section.rfa ......... Shaped Sill CMU-Side.rfa ......... Shaped Sill CMU-Top.rfa ......... Solid CMU-Section.rfa ......... Solid CMU-Side.rfa ......... Solid CMU-Top.rfa ......... Split Face CMU-Section.rfa ......... Split Face CMU-Side.rfa ......... Split Face CMU-Top.rfa .........
