Links are displaying in grey in one view
yuri0167
Message 1 of 22
yuri0167
Hey Im doing a detail drawing and have a bunch of links loaded into my project. For some reason the cut lines in the view are displaying in halftone and I cant figure out why.
I tried to find the reason in my view template but didnt succeed. Any thoughts on how to fix this?
Replies (21)
Message 2 of 22
Are you sure they are coming from the links?  If so, they must be Model Lines or Datums since Links are set to BY HOST.  That help?  In other words, the Parent Project settings are in charge, so to speak.  Can you TAB-Select these lines?  Override in View By Element?
Message 3 of 22
Expand these.
Message 4 of 22
yuri0167
since the lines belong to a roof in this case I cant select the lines individually. But when I select the roof I also cant override graphics in view. So it seems like it is locked somewhere. The weird thing is that I was able to change the view template and the elements werent half tone anymore, so it is possible to change it somewhere in VG I just dont know where...
Message 5 of 22
yuri0167
should I override?
Message 6 of 22
You don't have access to it because there is a View Template applied. But you can identify it. What is it? Check the Properties of the element when you TAB-Select it.   That's what you are looking for under VGOs=>Revit Links in the Template.
...wait a minute. Links are BY HOST. Whatever it is, is controlled by the Parent Project Category settings.
Message 7 of 22
yuri0167
exactly it doesn't necessarily have anything to do with the links, I set everything regarding the links to by host view and I also overrode the 1 (<not shared>) parameters. nothing changed.
Message 8 of 22
Post the files. Parent + the one Link.
Message 9 of 22
@yuri0167 wrote:
should I override?
No, don't override, leave them as they are.
Did you check the links' phase mapping?
Message 10 of 22
yuri0167
its a BIM360 file so I dont think youll be able to open it. And through save as the file path for the links will stop working.
Message 11 of 22
Can you state the issue again?  It's that the element is halftoned; right?  Is Grey Inactive Worksets checked?
Message 12 of 22
yuri0167
the view is set to new construction.
and all the elements from links are also created in new construction
Message 13 of 22
Not that.  Phase mapping as in selecting a link and Edit Type.
Message 14 of 22
Not that.  Phase mapping by select a link and Edit Type.
Message 15 of 22
yuri0167
Gray inactive worksets isnt checked
Message 16 of 22
yuri0167
Message 17 of 22
What is the view's discipline?  Try Coordination.
Message 18 of 22
@ToanDN wrote:
Try Coordination.
...or drinking. Too early?
Message 19 of 22
yuri0167
in DK its friday evening after all...
Message 20 of 22
yuri0167
discipline is Architecture
