Linking IFC from civl 3D to Revit 23
jaouher_talbi53LH2
jaouher_talbi53LH2
Hello everyone,
I am working in Autodesk Revit 2023 and need to link an IFC 2x3 file exported from Autodesk Civil 3D. The IFC file is correctly hosted in Autodesk Construction Cloud (ACC).
When I link the IFC into Revit, the model appears very far from the origin, likely due to georeferencing.
However, when I link the DWG exported from Civil 3D, Revit displays a prompt asking to align the model. After clicking “Align,” the file is positioned correctly.
My question is:
Is there a reliable workflow to link a georeferenced IFC into Revit so that it is placed correctly from the start, similar to the DWG alignment behavior?
Thank you.
Ahmed_M_Heteba
Are the files exported from C3D sharing the same shared coordinates and site with Revit file?
As if not this might be the issue.
Ahmed Heteba, PMP, bsi, B.Sc, AEE, ACI, ACP
Senior BIM Manager @ EllisDon
jaouher_talbi53LH2
Yes, as i saw in other forums the problem comes from the Exporter of C3D. i found a solution here : Solved: Export IFC - wrong position ! - Autodesk Community
Thank you !
