- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello everyone,
I am working in Autodesk Revit 2023 and need to link an IFC 2x3 file exported from Autodesk Civil 3D. The IFC file is correctly hosted in Autodesk Construction Cloud (ACC).
When I link the IFC into Revit, the model appears very far from the origin, likely due to georeferencing.
However, when I link the DWG exported from Civil 3D, Revit displays a prompt asking to align the model. After clicking “Align,” the file is positioned correctly.
My question is:
Is there a reliable workflow to link a georeferenced IFC into Revit so that it is placed correctly from the start, similar to the DWG alignment behavior?
Thank you.
