Linked Structural Columns showing walls passing through them
ferchichi.ghacen
ferchichi.ghacen
Hello Everyone,
We are having graphics issues when linking Str models into Arc Models related to columns showing walls passing through them as illustrated below :
We are using floor Plans and the column family is pre cut in plan view :
Regards
b.ross
Try changing the "Dicapline" feild in the view.
you may need to reconsider how you are modelling - are you proposing a wall passing through this column, or are you proposing a wall meets this stuctural column and a lining system wraps it?
o.a.sokolovskyi
If this column in linked model and you need only visual decision - you can use visibility/graphics override or filters and override walls and columns in black.
Oleksii Sokolovskyi | Олексій Соколовський
BIM Manager & Consultor | BIM Менеджер & Консультант
Autodesk Developer Network Member
Revit in Ukraine Co-Founder
Facebook | LinkedIn | RevitInUa
You can copy monitor the structural column to your model, join geometry with architectural walls to clean up the wall intersection.
ferchichi.ghacen
Hi @b.ross ,
actually i mean it to pass through.
