Linked Structural Columns not showing Cut Pattern VGO consistently across all levels
jagostinho74
Message 1 of 12
jagostinho74
The VGO Cut Pattern is not coming through consistently for all levels for Struc Columns at the same location.
This only seems to affect the views in Revit as the PDFs are coming out fine.
But it is still very annoying.
Anyone also having this problem?
Any acceptable workarounds?
Thank you
Assistant BIM/CAD Manager
Manchester, UK
Replies (11)
Message 2 of 12
amarkonathala
Hi @jagostinho74
Did u checked by Overriding the Surface pattern also...
Message 3 of 12
jagostinho74
I did, @amarkonathala , yes.
did not work.
Thank you for asking.
Manchester, UK
Message 4 of 12
amarkonathala
Try it making filters by Family Type names
Message 5 of 12
cbcarch
Try using a Custom VG Setting with a Filter for Structural Columns Cut Pattern and apply to a View Template for Linked Struct. Columns in all your plan views.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Message 6 of 12
jagostinho74
Tried that. Did not work.
Also tried editing the columns "Show family pre-cut" and Symbolic Representation" properties without success.
And tried to set the Walls transparency to 1 but that did not work either.
Manchester, UK
Message 7 of 12
cbcarch
In Revit, check the VG of the Plans that are working correctly. Then compare to the VG of the plans that are not working correctly.
  • Are any of them overridden individually ( Override Graphics in View)?
  • Is Analytical Model View set on any views/view templates?
  • Are you using By Linked View in any Views/View Templates?
  • Is the Cut Plane set above 48" on all views?
  • Are any Plan Regions being used?
  • Have you (or can you) open the Linked Model and see if it displays correctly by itself?
Cliff B. Collins
Message 8 of 12
jagostinho74
  • NO Are any of them overridden individually ( Override Graphics in View)?
  • WILL CHECK Is Analytical Model View set on any views/view templates?
  • NO Are you using By Linked View in any Views/View Templates?
  • YES Is the Cut Plane set above 48" on all views?
  • NO Are any Plan Regions being used?
  • YES Have you (or can you) open the Linked Model and see if it displays correctly by itself?
Thank you for these suggestions @cbcarch . Answers above in Green.
The View Range is set by the View Template and different Cut Plane values seem to affect the graphics differently (images attached below).
Also finding that zooming in and out changes the way how they look. See GIF attached below.
jagostinhoCT_0-1617293118531.pngjagostinhoCT_1-1617293127624.pngjagostinhoCT_2-1617293139000.png
Manchester, UK
Message 9 of 12
cbcarch
I'm wondering if it is a graphic card problem, since they print correctly to PDF, but the GIF shows them acting strangely in Revit.
Try changing Hardware Acceleration. https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/sfdcarticles/sfdcarticles/C...
Cliff B. Collins
Message 10 of 12
jagostinho74
Hi @cbcarch ,
Just tried with both Hardware Accel. ON and OFF and the problem remains.
Following your suggestion, I also checked for the Analytical View for both views and it was OFF.
The reply I got from the Autodesk Elite Expert from the ticket I submitted is that this is likely to be a bug.
Manchester, UK
Message 11 of 12
sureshchotrani
Have you used any addin for this particular file, addins are known to cause such corruption by modifying the elements.
www.bim-3d-4d-5d.blogspot.com
www.bim-navisworks.blogspot.com
Twitter @SureshChotrani
Give KUDOs if happy & accept solution if post provides solution
Message 12 of 12
jagostinho74
That is a good suggestion, thank you @sureshchotrani.
Autodesk Support is labeling this as a bug.
Manchester, UK
