Linked Revit Models Showing as Wireframe
serigot
Message 1 of 8
serigot
I am working in Revit v.2024 (although the same was occurring in v.2022). I have opened up a piping model and linked in an architectural model for walls and a separate model for equipment. When I create section cuts, the visibility of the linked architectural and equipment models look to be in wireframe mode, so I'm seeing all of the piping and equipment through the walls which should be opaque. I've changed the discipline of the architectural model to "Architectural" in the display settings dialogue, but it has not affected the visual display of the linked model. This could be a discipline issue, but still can't seem to diagnose. Any help appreciated!
Sarah
Replies (7)
Message 3 of 8
syman2000
Do you have link underlay turned on? I do get wireframe when that box is checked on
Message 4 of 8
How far from the Internal Origin of the Project are you modeling?
https://help.autodesk.com/view/RVT/2023/ENU/?guid=GUID-3F79BF5A-F051-49F3-951E-D3E86F51BECC
Message 5 of 8
serigot
The issue seems to be discipline related. If the plan view is set to "Plumbing" discipline, I can't see section call-outs that are denoted as "Architectural" discipline. However, if I don't have the discipline set to "Architectural" in the section cuts, the links all show as wireframe instead of hidden line. So my workaround was to set the plan discipline as "Architectural" but then all the section cuts with the "Plumbing" designation do not show. My overall intent is to create section cuts within this plumbing/piping model that can be viewed in hidden line, but keep all designators as is.
Message 6 of 8
RSomppi
Architectural backgrounds normally show through pipe, duct, etc.
As to your section problems, it's hard to follow what your saying. Can you provide screenshots that depict the issue?
Also, you might want to ask an admin to move your post to the Revit MEP forum. You can do this by reporting your OP and asking for it to be moved.
Message 7 of 8
Set the view to Coordination discipline.
Message 8 of 8
patilm2W7UGW
Community Visitor
Community Visitor
It worked,
Thank you
